ARRGHHH...Smog Referee doesn't recognize my ECM
Old Mar 13, 2009 | 01:56 AM
Mr.84TransAmer's Avatar
Car: '84 Trans Am; '88 GTA
Engine: Vortec 355ci TPI
Transmission: TH-700R4
I'm hoping someone here has a GM Crossreference manual or something similar. The smog referee failed my TPI motor swap because, among other things, his manual does not crossreference the 16198259 ECM as a replacement to the 1227165 ECM specifically in cars with VIN code "8" (L98 F-bodies). So I need to present to him a scan from an official GM manual that will crossreference the newer ECM for the older one on thirdgens. If anyone here has a GM guide and they can scan that page for me, I'll be more than happy to buy them a beer or two (provided I pick the bar!). My car's getting prepped for an upcoming show this week so I'm on a time crunch. Thanks.
Old Mar 13, 2009 | 12:53 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: ARRGHHH...Smog Referee doesn't recognize my ECM
Man that sucks, hope you find what your looking for. Did they run it on the emissions dyno? I'd bet it probably ran cleaner then the old carbed engine your replaced..That's crazy that the facists out there are that **** about things, here they'd just run it on the dyno and if it ran clean enough you'd be on your way. I really doubt they'd even know a tpi engine wasn't factory for 84 unless you told em in NJ.
Old Mar 13, 2009 | 03:48 PM
Actually it failed pretty badly because Painless Wiring gave us sh*tty instructions on how to wire up the park/neutral/safety switch that they sold us, so It wouldn't even go into closed loop operation when they'd shift into drive. So now we gotta go back and get on the phone with them. How they chose the name 'Painless' is beyond me.
But yeah, someone here's has got to have a manual with the ECM numbers.
Old Mar 13, 2009 | 03:59 PM
Stephen's Avatar
Car: 87 GTA
Found this, although it won't do anything for a referee. But maybe the poster has more information to back it up?
Thought about asking a Chevy stealership for documentation, showing it is a replacement ECM?
https://www.thirdgen.org/forums/dfi-...1227165-a.html
Old Mar 13, 2009 | 05:18 PM
Yeah I found plenty of threads about the two ECMs but I don't think that would cut it. Chevy thunder has a diagram that works for both again it's not "legit"
http://chevythunder.com/1986-89_tpi_ecm_schematic.gif
Here's a crossreference online but again, no GM endorsement.
http://jbody.net/16198259
Old Mar 15, 2009 | 10:16 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, I think you'll have to find a knowledgeable dealership to help you.
Mark Christopher Chevrolet in Ontario, CA
Scoggin Dickey in Lubbock, TX
Pace Performance in Niles, OH
Gilbert Chevrolet in Milton-Freewater, OR
Burt Chevrolet in Englewood, CO
Those are some good ones I know about.
Old Mar 15, 2009 | 10:26 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
the real problem with painless is that they dont normally wire for smog equipment. when they do its after wiring and not always correct. your smog equipment may not even be working. i had mine checked when i got it from a buyer - it was a complete tpi including brain box.
what are you doing infront of a referee anyway?
i will look to see if i have the manuals for that but i dont think so.
GTAman
Jul 3, 2024 07:29 PM
skeltor
Feb 2, 2016 10:37 AM
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Jlanz55
Sep 8, 2015 11:28 PM
