gen 6 DFI harnes question????
Old Apr 13, 2009 | 12:05 AM
fastsspr's Avatar
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
Were can i find a place to buy a harness adapter to use the DFI with the factory wire harness of a 91 z28 tpi?
Old Apr 13, 2009 | 04:30 PM
Gary Anderson's Avatar
Re: gen 6 DFI harnes question????
http://whiteracing.com/faq.html
Old Apr 13, 2009 | 09:09 PM
fastsspr's Avatar
Engine: 305ci 5.0L
Originally Posted by Gary Anderson
Thanks so much for your help. I alrady called them.
Old Apr 13, 2009 | 11:13 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
email this person brian@brianmacy.com, I just talked to him a few days ago, he is from a place called Horse Power Connection that makes them they used to be fast track performance, thats where I got mine, the cost is $599, their website is not coming up for some reason, they have been around for a while.
Old Apr 14, 2009 | 11:21 PM
fastsspr's Avatar
Engine: 305ci 5.0L
I called Dan at Whiteracing and build it for $275 he also says i need to ad something he called a buffer is make factory gauges in the dash works that is additional $175 for the interface harness.
Know if have a question if i use the gen6 dfi in the 91 z what i going to do with the VAT system? It going to still doing it function ? Is any one who have experience with DFI in tpi cars?
Old Apr 14, 2009 | 11:28 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
The adapter should allow eveything to work as is, when I had my GEN 6 wih the adapter to the factory harness eveything worked, I did not need to add anything for the gauges to work, the VAT woked fine. I have since upgraded to a GEN 7, I talked to whiteracing also and they do not make a harness for this set up at this time.
Old Apr 15, 2009 | 04:50 PM
fastsspr's Avatar
Engine: 305ci 5.0L
But you use both sistem at the same time DFI and factory ECM? If i deside not buy the buffer option i not going to be able to start the engine because the VAT?
White Racing already quoted me the harness for $275 + the buffer $175.
Thanks man.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
marcusaw
Aug 10, 2015 08:13 AM
