Commander 950 (950-101) Guys Inside Please!
Old May 4, 2009 | 01:45 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Hey guys! I'm in the process of installing my C950. I got the old harness out yesterday and tonight I'll be separating out just the wires that I need to run the electrical system, fuel pump relay, ran relay etc...
My question today is for those of you who have installed the 950-101 P/N... how did you route the wiring harness? Did you punch the 2" hole through the firewall as is mentioned in the instructions, or did you go through the inner fender and into the passenger compartment through the kick panel like the factory setup goes?
Thanks in advance guys!
Chris
Old May 4, 2009 | 07:53 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: Commander 950 (950-101) Guys Inside Please!
mine goes through the inner fender and into the passenger compartment through the kick panel like the factory setup goes. i dont know to much about the installion, a shop did mine.
Old May 4, 2009 | 10:08 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Well I got into it again tonight. I ended up routing it through the inner fender and kick panel like the factory harness. Everything for the C950 is long enough... EXCEPT FOR THE O2 SENSOR CONNECTOR! Got to figure that one out tomorrow. I'm going to be running the Wideband Upgrade... so I've got to figure out where to mount the wideband controller and make sure its close enough to get the sensor to it...
Then... time to try and fire it up... Keep your fingers crossed for me guys!
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
355tpipickup
Aug 19, 2015 10:02 PM
Street Lethal
Aug 14, 2015 08:25 PM
