Bypassing Speed Limited TBI Cars
Car: 1992 Camaro RS
Engine: L03 305 TBI
i so i cut the brown wire A10 comming from the ecm and installed a switch to turn off the vss (vehical speed sensor) but when i turn it off i don't get a service engine light or anything. i did drive around with it off for a while and still didnt get a light. i want to see if i get the right error code (24) but can't if i don't get a light. so im wonderin whats up. thanks
http://www.austinthirdgen.org/index.php?pid=7.
Car: 87 GTA
Re: Bypassing Speed Limited TBI Cars
When you cut A10, did you connect both cut ends to the toggle switch?
Dumb question, I know, but......
Car: 87 GTA
Yes, you should.
Hmmmmm......I wonder if it was written up wrong?
Or you misread the connection you used?
Or if your was was miswired/rewired at some point in its life, changing things somehow?
Car: 1992 Camaro RS
Engine: L03 305 TBI
maybe when i get new tires ill see if the mod stops the speed limiter because as of right now my tires are shot and i dont trust them.
Car: 87 GTA
When the ECM loses the VSS signal, the SES should light up, unless your chip already has it removed from the tuning. Stock chip? SES light bulb out? Does the SES light initially come in, when you first turn the key? Maybe the bulb is out......
Car: 1992 Camaro RS
Engine: L03 305 TBI
yeah my service engine light works. the thing with the tires is i know that it won't effect the ecm but i just don't want to blow a tire out at 120 mph. im pretty sure it is a stock chip because when i bought the car i was testing it out and i hit the 115mph wall so.
