tuning pointers please!
Old Sep 18, 2009 | 11:03 AM
bmfIROC-Z's Avatar
my car kicked a ces light a while back and i found out i have to buy a scanner or buy a cable & software and connect it to my laptop to see what codes were thrown,so i figured what the heck ill buy the cable for diagnosis and eventually learn how to tune with it,so where should i start? what will i need to start tuning?and is there any good tuning articles to help guide a tuning newb? any pointers would be greatly appreciated,thanks in advance.
Old Sep 18, 2009 | 11:43 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: tuning pointers please!
You don't need a cable to see the codes.
Jumper the A & B pins on the ALDL connector and the SES light will flash the sequence indicating the number of the codes that are set.
Some older setups need a 10K resistor to log data but I don't believe it is needed to flash the codes on the light.
Tuning is a whole nother thing. Check out the DIY_PROM board stickys for enough info to make you eyes bleed.
Old Sep 19, 2009 | 11:40 AM
bmfIROC-Z's Avatar
yes i do need a cable,some 94's you can read the codes that way and some you cant ,mine is one that ya cant.
Zell1luk
Sep 29, 2015 10:36 AM
