LT1 no spark?
Old Sep 30, 2009 | 02:44 PM
SanFranCyco's Avatar
Car: 87 GTA
Engine: L98 5.7 24#inj,World hds,MSD,nosmog
Transmission: 700R4 truck clutches,Trans go shift
Axle/Gears: 10 bolt chevy 3.73 limited slip
LT1 no spark?
I have a 95 caprice withe yhe LT1. The car died and I got a "check gauge" on the cluster.so i checked for fuel(fine) and spark(none).I'm not getting spark to the dizzy and and i just replaced the coil.Is there anyway to test the control module or does anyone have any suggestions on the problem.anything will be highly appreciated.Thanks
Old Oct 2, 2009 | 05:27 PM
gta87ls1's Avatar
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
Re: LT1 no spark?
those optispark distibutors are a common problem. also make sure ur harness going to it is good because I have also seen some of them cause this problem.
Old Oct 6, 2009 | 01:12 PM
Socalz's Avatar
Car: 85 IROQ
Engine: 5.7
Axle/Gears: 10 bolt 3.42
Re: LT1 no spark?
A parts store should be able to test the module. What is the code of the ses?
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
