Mega Squirt Questions
Old Oct 31, 2009 | 10:37 AM
DAIGS1985's Avatar
Car: 1985 T/A
Engine: 355 TPI
ive built my MS2V3 all the way and it works with the stim and the MT but i have a few qestions
~the IDL led on the stim wont light up and led isnt burt out
~on the relay board what are the what are the 4 connectors for that are labeled injector 12v
for
~also how r u supposed to wire up the injectors for 8 if theres 4 outputs-then which bank should go the INJ1&2 and theres 2 of those
if anyone has wiring diagrams or knows where they are in the megamanual that i am most likley over looking
any comments or criticism are welcome as long as there constructive
Old Oct 31, 2009 | 06:34 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: Mega Squirt Questions
go to msefi.com MS-II and V2.2/V3 Main Board Assembly, Testing, and Troubleshooting and Matt Cramer will give You all the help. as for wiring here is the link http://www.megamanual.com/ms2/v3ext_wiring.gif
best reagrds
Old Oct 31, 2009 | 07:34 PM
project89's Avatar
for
i can help u with the injector wiring, the ms is a batch fire system, so for each bank u will wire in 4 injectors i.e 4 gounds to the inj1 ground wire, and 4 hot wires form the injectors to the hot inj1 wire, same for the others side
inj1/inj2 just is just the diff banks u can out bank one or 2 on either side of the engine it does not matter.
on my car i did bank1/inj1 as the passenger side and bank2/inj2 driver side
im not sure about the relay board cause i didnt use one though
colton_carlson
Mar 8, 2019 12:21 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Thornburg
Aug 27, 2015 08:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
