Easy question just need numbers and colors
Car: 1987 firebird formula
Transmission: 5-speed
So im trying to get all the kinks worked out of my formula and because they got all mixed up and i dont know I have a very easy question.... what are the part numbers for MAF power AND burnoff relays? and what color wires go each relay . Thanks and pictures ALWAYS help
Car: check
Engine: check
Transmission: check
Re: Easy question just need numbers and colors
RBob.
alright so i went out and i bought one mr22 which is the power relay and one mr5 which is the fuel pump relay. the mr5 is not like the mr22 its a different style and i dont know where it goes.... any help on that? the other wierd part is that i traced down which relay was the fuel pump by removing the 3 relays and individually hooking them up till the fuel pump primed at the "on" so i was down to burn off and power relays. anyway point is my car used to run ok but would kind of sound like it was missing and would stall a lot at stoplights etc but now after messing with the relays it runs amazing with no missing but idles really high and i actually have to idle it down, why would it do that? and lastly when i was messing with them i left the car running and unplugged one and both of the maf power and burnoff relays and the engine didnt act any different, does that mean my MAF is bad? sorry this is so long but it should make sense.
also which one of the relays is the 4 prong connector, the burn off or power? the other two are five prong connectors.
LT1Formula
Aug 20, 2015 09:36 PM
