Is My ECM Bad?
Old Mar 19, 2010 | 01:41 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Is My ECM Bad?
I have an 86 IROC, 305 TPI. My alternator recently shorted out on the valve cover and started a small fire. No prob, new alternator and wires fixed it. Now I am getting a code 15, Low Coolant Temp on my ECU. I checked for an open circuit on the CTS, it checks out good. Voltage side is right where it should be. While checking wires I found that almost all of the wires that should not read anything unless the ECM tells them too are reading .3 volts. I am thinking that my alternator shorting out may have ruined my ECM. Also, when I run a diagnostic check my fan comes on while the jumper is in and doesn't turn off until I remove it. Is this normal, is my ECM bad, or what circuits could cause this?
Old Mar 19, 2010 | 12:09 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Is My ECM Bad?
the fan turning on in diagnostic mode is completely normal.
Old Mar 19, 2010 | 02:47 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Re: Is My ECM Bad?
Thanks for clearing that up. Any idea on the .3v in the wires that shouldn't read anything according to what I have seen? I was running great until my alternator shorted out.
Old Mar 25, 2010 | 08:43 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Re: Is My ECM Bad?
Good to go. If anyone cares, after checking all of my wires and signals with a multimeter and everything else I could think of I found that the problem was at the sensor itself. I put in a new sensor already so that wasn't the problem. I pushed in on the plug and Wa La. The plug is not making good contact. Temporary fix: I took off the rubber seal and pinched the sockets a little with the needle nose. Long term fix: I ordered a new plug.
Old Mar 26, 2010 | 09:20 PM
bcmag's Avatar
Re: Is My ECM Bad?
i believe the make replacement pig tail connectors for these.standard,everco etc.congrats on finding your problem!
skeltor
Feb 2, 2016 10:37 AM
88rscamar0
Sep 23, 2015 09:08 PM
Billy Decker
Sep 4, 2015 03:46 PM
willyjoejr
Sep 3, 2015 09:26 AM
RyanJB
Sep 2, 2015 01:27 PM
