stand alone fuel management system
Old Apr 11, 2010 | 08:50 PM
ChevyRS-305's Avatar
i need some help on finding stand alone fuel management systems that runs of a pc for my engine build up. i found an intake manifold from hogan that im pretty much set on but then realized that if im going with efi and injectors that i need some sort of a computer module. keep in mind that my car is completely rebuilt from the ground up and nothing is left of the factory harness let alone my factory ecu(garbage). and yesterday i found the edlebrock pro flo system and it is exactly what i want but the intake and throttle body is set up as tbi and not tpi with injectors... is there possibly someway i can just use my hogans intake and throttle body with injectors and just use the edlebrock software system and sensors? i need some help and im so confused when it comes to this stuff!!! aaahhhhh
Old Apr 12, 2010 | 10:53 AM
1badbotie's Avatar
Car: 1988 IROC-Z
Engine: Fast Burn 385 Crate Engine / Accel DFI
Axle/Gears: 10 Bolt Auburn Pro / 4.10 Gears
Re: stand alone fuel management system
I have a DFI Gen 6 complete with wiring harness. You can use it on any EFI intake you like.
Old Apr 12, 2010 | 11:40 AM
Ronny's Avatar
dynamicefi.com. Datalogging-learning-.bin creation all in one. User friendly. Will handle port fueling. GM sensors.
Old Apr 12, 2010 | 11:47 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
MegasquirtII - GM sensors calibrated etc.
best regards
evilstuie
Jan 9, 2020 08:29 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
