no code 12=bad ECM?
Old May 24, 2010 | 04:45 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
no code 12=bad ECM?
I'm not getting a code 12 with the engine off and the key on(no SES at all), does this mean my ECM is bad? what else could it be?
Old May 26, 2010 | 01:59 AM
ericjon262's Avatar
Re: no code 12=bad ECM?
anyone?
Old May 26, 2010 | 09:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
How does the engine run? Decent, or really bad? If it runs decent then it just may be that the SES bulb is out. Or that the wire from the ECM to the SES is open.
RBob.
Old May 26, 2010 | 10:19 AM
ericjon262's Avatar
RBob.
it runs, but really bad, the bulb may be out, but it's not showing any codes on my laptop either, not even a 12.
Old May 26, 2010 | 10:54 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Are you getting any ALDL data at all? If not it may be that the ECM is dead and is running in limp mode. This is on a back up fuel device.
It will run but not very well in limp mode.
RBob.
Old May 27, 2010 | 12:03 AM
ericjon262's Avatar
I'm pretty sure I was getting data, I woudl have to break the laptop back out to make sure though.
Old May 27, 2010 | 05:36 PM
ericjon262's Avatar
I still haven't had a chance to check if it's transmitting data, but I do have a new development, it runs best between 2000-3000 rpms, it'll usually die if I rev it in neutral without feathering the gas back down, and sometimes when the engine is under high load, it will stumble and backfire insanely bad,
Old May 27, 2010 | 06:21 PM
EagleMark's Avatar
That could be limp home... test the SES bulb or run a test light from the wire on ECM to SES light...
Old May 27, 2010 | 09:16 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Won't get ALDL data in limp mode. Actually sounds like the fuel pressure is dropping off.
RBob.
Old May 27, 2010 | 11:19 PM
ericjon262's Avatar
RBob.
I just replaced to fuel pump, so that would mean I would have to have a bad regulator. also, sometimes it'll run well all the way to 5500 rpms.
That wouldn't explain no code 12 though, any other ideas?
Old May 27, 2010 | 11:30 PM
EagleMark's Avatar
Yes. Have you checked the bulb? Does it work ever?
Just because you replaced a fuel pump does not means it's working corectly. If you think there is a fuel presure problem you use a fuel presure gauge to check. Not replace a part...
Old May 27, 2010 | 11:35 PM
ericjon262's Avatar
I checked it through the diagnostic port, no codes at all with the engine off.
My car got ransacked the same day it quit running right, I dropped my tank thinking someone put something in it, and since I had it out I decided I better do it now instead of later.
Old May 27, 2010 | 11:59 PM
ericjon262's Avatar
I just checked, I am recieving data through my link cable, map, o2, TPS, ect ect, but no fault codes.
Old May 28, 2010 | 02:24 PM
ericjon262's Avatar
New development, I stopped by the gas station and put gas in it, and now I have code 12 again! I can already tell this won't be easy!
Old May 28, 2010 | 04:39 PM
ericjon262's Avatar
and now it's not running, I'm thinking it's the ICM.
89GTAOz
May 16, 2020 09:31 AM
Cornholio7979
Sep 20, 2018 02:31 AM
mddaniel
Sep 8, 2015 05:16 PM
Jae992
Aug 27, 2015 09:07 AM
