How Can I Bypass Fuel Pump relay
Old Aug 12, 2010 | 09:43 AM
Jon92camaro's Avatar
how can i bypass this FPR just for 1 quick drive till i can get a new one i have court and either my pump or realy has gone out have court in 2 hours any help please
Old Aug 12, 2010 | 10:10 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: How Can I Bypass Fuel Pump relay
car should still run, may take couple extra seconds to start, but should run off the oil pressure sending unit (which senses oil pressure and runs the fuel pump).
But, on the relay connector, if you connect the orange wire with the grey (I think) wire, the pump will run. Just take a small piece of wire, crimp a spade connector on each end, and stick them in the relay connector.
Of course, this all assumes your pump is working - if the pump is dead, you're out of luck, grab a cab!
Old Aug 12, 2010 | 10:12 AM
Ya ty ill go try that i found my spare relay actually i been looking around but finally found it its brand new so if it doesnt work then yes the pump is toast
Old May 14, 2012 | 08:01 PM
all4chevy's Avatar
i need some help . i'v got a 1990 rs,the fuel system has shut down,could this be the computer?
Old May 14, 2012 | 09:41 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
pump or relay ... make a thread dont revive a two year old thread just to jack it... lol
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
