lt1 injection to carb questions
Old Dec 2, 2010 | 09:43 PM
Voider's Avatar
Ok i have a 1997 lt1 i pulled from a 97 trans-am that i plan on putting in a 76 camaro, first i want to convert it to carb, what is the cheapest/easyest way to get the distributor to run without the factory ecm/pcm? does anyone sell a distributor that will fit this engine without block modifications that runs as a stand alone unit? or is there somewhere i can get a controller that will run the distributor by itself without needing all the injectors and senceors runing? any tips or info would be greatly appreciated.
Old Dec 14, 2010 | 01:58 PM
595X's Avatar
Re: lt1 injection to carb questions
Did you ever find out the answere to your question here? if so, i would like to know as well! Thanks alot....
Old Dec 14, 2010 | 07:57 PM
Voider's Avatar
The best way i found was to get a lt1 carb intake and put a regular rear mounted HEI distributor on, i got the GMPP LT1/LT4 2 plane carb intake and it seems to work, i think mopar also makes intakes for lt1 carb setups, not sure whole else does, i've seen where some people pluged the wholes for the optispark with plugs or welds but i just removed the roter and left it on there to fill the whole.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
