aldl to usb cable probs
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
maybe its because i'm new to this whole thing but has anyone else had problems with this cable... i've tried with winaldl and tunerpro and can't get a read on anything with the key on or the car running... any thoughts... ? maybe i don't have the program set right but i know i have the com port right..
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: aldl to usb cable probs
Ok so somebody can help you..
What cable? ALDL.com?
Please verify ECM, BCC & ADS or ADX #'s used.
Momentary resistor short may be necessary.
Car: 1991 Z28
Engine: 355 TPI
http://aldlcable.com/sc/details.asp?item=aldlobd1u
Now i'm new to this so i need to know where to find the numbers for the ECM, BCC & ADS or ADX... maybe an explanation as well as to what they are...
ECU # would be on label on same. Like 1228746. Or can be referenced by year make model. 1991 camaro tpi is 1227727 or 1227730. BC is also on label or on prom under access panel like AYKC. ADS/ADS is the mask or definition file or program byte like $61 for above ECU 8746. both 7727 and 7730 use $8D.
Transmission: TH400
ADS (TPv4) & ADX (TPv5) files configure data for transmission/reception thru the ALDL.
Seems I often find them bundled in the ECU or BIN (XDF?) files.
I hope another member will verify this as engines, not code, is my forte.
Transmission: TH400
Ok so your response helps us to know where your at.
The proper .bin and .xdf files must be first loaded into TP to use the program, that is I still haven't tried connecting without, maybe others have.
.bin files store the "tune" parameters (settings),
.xdf files are, as Ronny said, a directory to those settings.
The best advice I can give a new guy is Read Stickies!
Car: 1991 Z28
Engine: 355 TPI
yeah i haven't even messed with it at all since it pissed me off.. I do know the ecm number now though but don't have a bin file to load... i'm really trying to just read whats already on the ecm with either winaldl or tunerpro... can that be done without having the bin file???/
Transmission: TH400
No,
WinALDL is limited to the pre-loaded ECM's in 'configuration'. I don't see the 7730 or 7727 there. That program is for monitoring & datalogging only.
I'm sure you need to load TP RT with .bin & .xdf to connect, like I said I've never tried it without, I don't see how that would work. Like winaldl connecting allows you to monitor & datalog. TP is also a slick editing program.
Find your .bin & .xdf files here http://www.diy-efi.org/gmecm/ecm_info/1227730/
ftp://ftp.diy-efi.org/pub/gmecm/
That is what's on a stock chip.
You can read what is on your existing prom with some Moates gear, a Burn2 & HDR1 would do the trick. Read this to start, http://support.moates.net/2009/05/07...guide-read-me/
Don't get mad that won't help anything...lot's of reading stickies will.
Car: 1991 Z28
Engine: 355 TPI
its no longer a stock chip i had it burned by a guy on here i know and i know its a moates chip with the adapter and all that jazz just not sure if i need the .bin and .xdf files he used to load on the chip to read it... what i really want is to just be able to connect to the damn thing and monitor the sensors and see whats going on with the motor...
so in order to emulate or "monitor" my ecm currently i will need the .xdf and .bin files or can i connect to it and pull them from the ecm?
Transmission: TH400
You will need more gear to "read" a chip.
Try to get your .bin & .xdf from the author.
If not,
I would try loading the stock files, if the changes were minimal you should be able to establish data flow.
If not,
Car: 1991 Z28
Engine: 355 TPI
If i purchase the extra hardware will that allow me to attain the files i need? Further i'm afraid to load the stock files because since i'm new to this i would not be sure what i would need to change to make the computer realize the upgraded components on my motor like mild cam and better injectors...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You might want to read the stickies or join www.gearhead-efi.com, If your using a 730 start with a $8d definition, Aujp.bin data log and adjust your ve.
Good stuff here to help you. Maybe you already saved to favorites and read up?
https://www.thirdgen.org/forums/diy-...uide-book.html
Car: check
Engine: check
Transmission: check
Don't see why anyone needs to go elsewhere...
RBob.
http://www.gearhead-efi.com/Fuel-Inj...ro-Tuning-Talk
There's tons of info here at Thirdgen forums DIY Prom, DFI and ECM and TPI just read the stickies and get an idea what's going on, be prepared to spend some time to read and learn. Lots of the info is advanced and will make sense as you move along.
You are already in the right place for your car here!
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
