1991 ECM - VATS helppppp! code 53
Old Mar 6, 2011 | 01:45 PM
1991_RS's Avatar
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
Recently purchased a 1991 RS with 305 TBI
Previous owner replaced ECM with wrong one. We have replaced the entire unit with one that we believe to be the correct one (1228746 AXKT)
The car will turn over fine and if reset, it will spray the injectors once before the security light comes on and shuts the fuel system down.
Car has new fuel pump, relay, lines, filter, and TBI has been rebuilt. Mechanic's scanner also shows #53 Security code. We have also made a jumper with the same resisitance of the key.
Is the VATS code part of the ECM that we replaced? If so, how do we find out what resistance the new ECM is looking for?
Old Mar 7, 2011 | 06:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1991 ECM - VATS helppppp! code 53
This should get you going:
https://www.thirdgen.org/vats
https://www.thirdgen.org/vats_passkey_system
RBob.
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
Jlanz55
Sep 8, 2015 11:28 PM
studebaker60
Sep 7, 2015 12:36 PM
RyanJB
Sep 2, 2015 01:27 PM
