5.0 TPI 5-speed ECM Help
Fellow members it has just been determined that the ECM on my 5.0 TPI 5-speed has gone haywire sending 6.0 volts to each injector and dumping massive amounts of fuel into the cylinders and oil. Car was never cranked in that state though. Dumped all the oil and will probably change a couple of more times. Does anyone know of a good supplier for Remanufactured ECMs? I don't guess new ones are available this many years later, but maybe so. Thank you.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 5.0 TPI 5-speed ECM Help
I have a couple 1227730 ecm's $60 shipped to the lower 48
you can see other options on www.rockauto.com
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
TPI has power to the injectors (12 V) and the ECM grounds them to open.
You will have power on both wires at the injector if you were to check them. Double check your wiring is not shorted between the injector and the ECM.
Engine: Lb9
Transmission: M20
I was thinking one of his multitecs were shorted and took out the injector driver
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
OEHQ.com, TPIS, TPIparts.net, maybe Classic Industries or Year One
Iroc8t8
May 4, 2026 08:09 PM
Sanjay
Aug 12, 2015 03:41 PM
