Bosch Design 4 Injector specs
Bought a set of these off FIC- rated at 24pph at 43.5psi, that's all the info provided. #280-158-138/7C3E-AB.
Looking for information relating to 'injector compensation' regarding EBL.
Re: Bosch Design 4 Injector specs
Looks like I found the answer- part numbers aside. 23pph = 24.242pph at 43.5psi
http://www.fordracingparts.com/downl...d_Adaptors.pdf
http://www.fordracingparts.com/parts/ics/m-9593-m23.pdf
Car: check
Engine: check
Transmission: check
Fuel Pressure: 43
Minimum PW @ 39.15 psi: 0.667
Minimum PW @ 43 psi: 0.683
Offset Compensation versus Battery Voltage:
6.4 Volts: 2781 usec
8.0 Volts: 1872 usec
9.6 Volts: 1392 usec
11.2 Volts: 1088 usec
12.8 Volts: 877 usec
14.4 Volts: 708 usec
15.0 Volts: 654 usec*
Flow rate: 25.4 #/hr
Short PW Compensation versus Pulse Width:
0.015 msec: -228 usec
0.244 msec: -182 usec
0.488 msec: -134 usec
0.732 msec: -85 usec
0.976 msec: -37 usec
1.220 msec: 0 usec
1.460 msec: 0 usec
1.708 msec: 0 usec
1.950 msec: 0 usec
2.197 msec: 0 usec
2.440 msec: 0 usec
2.685 msec: 0 usec
2.929 msec: 0 usec
3.170 msec: 0 usec
3.410 msec: 0 usec
3.660 msec: 0 usec
3.900 msec: 0 usec
RBob.
Car: check
Engine: check
Transmission: check
Does produce the 24.2 #/hr number.
The 25.4 #/hr number is derived from the data sheet. As the fuel pressure changes the flow rate doesn't change in the traditional sense of flow through an orifice.
The calculation for this uses the "AHISL (lb/s)" value and the FNPW_HSCOMP table.
RBob.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Oct 4, 2015 11:27 PM
