Best Tune
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Best Tune
I have a pcmforless mail order custom tune for my 383 custom build. My problem is i want all i can get out of the engine. So i was wondering is there a pcm tuning chip. I dont want to mail each chip and if that doesnt work change it. I heard there is some pcm chips that you can adjust with your laptop but dont know the name of them. Please any information will work. Thanks
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
Re: Best Tune
I'd recommend getting it dyno tuned, that truly the only way get the max power out of your setup.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Re: Best Tune
That's hard in las Vegas we don't have many good Dyno shops. I will have to do some research out here. Thanks duh
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Transmission: 5-speed/T-5
Re: Best Tune
Check out the DIY_PROM forum on this site.
The "chips you can change on the fly" are called "EPROM Emulators."
A popular one is the moates.net Ostrich 2.0. Auto Pro is also popular since it also combines the Ostrich with an ALDL logging cable and an EPROM programmer.
