Please help me. I am currently installing a Holley Commander 950 computer in my 87 l98.
I only have two wires to hook up. One is the fuel pump wire. the other is a switched power wire that needs to be hot in start and run. Where should I connect these wires please.
I have tried searching through shop manuals and such and cannot find the answers im looking for. Thanks for any info you have to offer.
Fuel pump wire goes to the positive side of the fuel pump. The switched 12v goes to just that as well, a switched 12v source. But make sure it's a power source that doesn't shut off during cranking. You'll need to check your fuse block for that.
Good luck!
Good luck!
Thanks its hooked up and running
