turnerpro Help
Old Aug 6, 2012 | 10:55 PM
91z28blue's Avatar
Car: 1991 z28
Engine: 5.7l TPI
turnerpro Help
hi guys
i got a 1991 tpi that i am trying to tune... i have some help for a friend how know his way around turner pro, now we can get live data like TPS,RPM.... but no marker in any of the tables to tell us were we are...
the ECM is a 7730 not sure if we have the right ads or adx file
from what i have been reading i should be using 88.xfd and or a $8D adx?
also every bin file we open look the same?
any ideas
thank Alex
we are using all moates stuff with the aldl connector
Old Aug 7, 2012 | 07:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: turnerpro Help
For a '91 TPI you want to use $8D stuff.
RBob.
Old Aug 7, 2012 | 09:58 PM
91z28blue's Avatar
Car: 1991 z28
Engine: 5.7l TPI
Re: turnerpro Help
i am working with $8D stuff and i just cant seam to get the locator (yellow box)on the charts to come up so i know we are going to make changes
Old Aug 8, 2012 | 12:34 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: turnerpro Help
You probably need to set up the DA association for the tracing to work. You need to edit each XDF parameter that you want to use tracing with to have it function.
haps
Nov 23, 2014 02:02 PM
Cambridge205
Jul 12, 2008 01:10 PM
smokefan
May 24, 2005 07:35 PM
