EBL compatibility Q?
I am thinking of replacing my original distributor with a Mallory model #61 part #6148201. Mallory say it is the only one I can use in my 1984 Chev Vette with original motor. Listed as for aftermarket FI 1955-1996 MY. I will use the Mallory Hyfire 6 box and HO ext coil. It uses Hall effect trigger with no module. a circuit board is utilized.
OK for EBL?
OK for EBL?
Car: check
Engine: check
Transmission: check
Re: EBL compatibility Q?
Won't work. It is designed to be used with the Edelbrock Pro-Flo EFI system. You need a distributor that will work with a stock GM ECM.
RBob.
RBob.
