Normal or bad ECM
Old Oct 9, 2012 | 06:51 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Normal or bad ECM
I have a 89 iroc with stock tpi. I have a custom piggy back chip for vats delete and to raise the idle other then that stock tune. I am using the tuner pro software to see what the engine is doing and when I am reading all the data there is like a glitch where all the numbers at the same time jump to a crazy number and then back to normal. It will do this evey 3-5 sec and I can hear a change in the way the engine is running that correlates with the numbers changing. Is this normal or is there something else going on
Old Oct 10, 2012 | 09:30 AM
EagleMark's Avatar
Re: Normal or bad ECM
http://tunerpro.net/forum/viewtopic.php?t=2215
89GTAOz
May 16, 2020 09:31 AM
mddaniel
Sep 8, 2015 05:16 PM
Jae992
Aug 27, 2015 09:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
