LT1 ECM with HEI Distributor
Old Oct 18, 2012 | 09:28 PM
dan_t's Avatar
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
What are my options here?
ECM is from a 1992 Corvette LT1
Motor is an Old School L98 (Fuel Injection) with External Coil, Small Cap HEI.
Swapping ECM is not an option.
I really want to try and keep this as simple as I can - it seems like if I can figure a way to feed the ECM the correct timing pulse I should be able to get everything else to play ball.
I've come across some snippets of information on a "Westwood Digispark" but it seems like their website (and I assume Co.) are no longer in existence.
I know that the cam in the motor is actually the "long pin" LT1 type - how about actually fitting an Opti-Spark to an old school SBC to get the signal? Possible? Timing cover fit?
Any advice or pointers greatly appreciated!
Old Oct 18, 2012 | 09:55 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: LT1 ECM with HEI Distributor
read something awhile back on putting opti guts into a large cap hei. was on thirdgen. just a thought
skeltor
Feb 2, 2016 10:37 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 6, 2015 03:05 PM
L0tuS
Sep 4, 2015 11:16 PM
