Accel DFI TPS Sensor Question
Engine: Dart 427 SBC
Axle/Gears: Ford 9" 4.10
I have an Accel DFI thruster series system for a small block chevy. It is the throttle body system. It was installed and then professionally tuned at a recommended accel dealer. I have a TPS sensor error 24. I have tried to reconfigure the sensor, its low set point is 4.84, and high set point in 5.XX after reconfiguring. I have reconfigured it twice and the sensor keeps displaying error code and defaulting to 100% WOT. Any Ideas?? The code recommends checking the wiring but it had to be working properly when it was tune.. Right? In addition, can I continue to drive the car and if so what will be the consequences?
