Holley fuel pressure sensor
Old Jul 26, 2013 | 07:03 AM
beast94's Avatar
Car: 1994 Chevy K1500
Engine: 355ci, TBI with vortec heads
I installed my new Holley fuel pressure sensor yesterday and I am trying to figure out why it is not working. It is a .5 to 4.5v, 100 psi device. The first time I mixed up the power and signal wires, and when I realized that I fixes the issue. Also I connected it to ADC port 1, and I also tried port 2. I also formatted the WUD to display it and it still does not report any fuel pressure. Does anyone have suggestion on possibly how to fix it? I am thinking it maybe bad.
Old Jul 26, 2013 | 08:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Holley fuel pressure sensor
Swapping the power & signal wires may have taken out the sensor. Measure the output voltage with a DVM to verify it. How to set up the WUD:
http://www.dynamicefi.com/ADC_Connect.php#WUD_SetUp
RBob.
Old Jul 29, 2013 | 07:10 AM
beast94's Avatar
Thanks Bob. I guess I will try replacing it. Also is it possible to add a oil pressure input to the computer and have it displayed on the WUD?
Old Jul 29, 2013 | 07:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There is only a single area for pressure display. Although, if not running a WB can make the oil pressure sensor a preferred WB device. It will display in the WB area.
RBob.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
