Gen 7 upgrade now old prog will not work "holes"
Old Sep 23, 2013 | 07:49 PM
FEDBYVORTECH's Avatar
My Gen 7 is the 13th one built. Sent it to Accel to have it serviced all outputs went high. They fixed and updated the firmware. They loaded my old program and said there would be "holes" a lot of info was messed up. I fixed most of it but still will not start. I have spark but no fuel. I spray some starter fluid in and she runs for a second. Pump comes on and pressure is good. Any one have a global setting (*.ecm) to get me close? I must be missing something.
355, 40lb injector 2bar map, wide band, small cap HEI distrib, Accel 300, vortech supercharger. Thanks for any info.
Old Sep 24, 2013 | 07:29 AM
efiguy's Avatar
Re: Gen 7 upgrade now old prog will not work "holes"
Send me your cal along with all of your engine specs including desired idle and WOT rpms. I'll see what I can do.
fastone01@hotmail.com
Mark
Old Oct 22, 2013 | 08:07 PM
Mark
Mark,
Thanks for the info. I finally got around to trying it. I have the same problem. Injectors are not turning on. Double checked the harness, swapped the computer with another one same ****. RPM in the DFI while cranking is 150. Fuel press stays at 50 while cranking. What else do I need to turn on injectors.
Thank you,
Joe
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
