Accel dfi ECM 74040A...Should I buy?
Old Nov 11, 2013 | 04:49 PM
1qk4mula's Avatar
Car: 91' Formula/88' Formula
Engine: 5.7L TPI/ 5.7 zz4 with mini ram
Transmission: 700r4/Stock T5
Axle/Gears: 10 bolt 3.23 /9 bolt 3.70
Hi, I hope everyone is doing well...
I have an opportunity to buy an accel ECM 74040a. I can't find the accel dfi site anymore, and can't get the information I need..
I have an 88 Formula tpi. I'd like an ECM that's programable and plugs into the factory harness and works with the factory sensors.. The ad where I found this ECM says it fits 80s corvette, camaro and gran nationals etc..
Will this ECM plug into my car? And what would I need to program this? Cables? Keys? Proms? Anybody know what generation this is and what are the pros and cons? Thx
Old Nov 12, 2013 | 11:34 AM
jonarotz's Avatar
Car: 91 Z28
Re: Accel dfi ECM 74040A...Should I buy?
That's an old unit...you would probably be better off with what you have. I am not sure if it will plug right into your harness though...I would guess its unlikely. It might be hard to find any wiring info on it since it is so old too.
Old Nov 13, 2013 | 08:30 AM
efiguy's Avatar
Silver casing?
If so then that's a Gen 6, older stuff. You need to run it in Doss, not Windows.
However there are still some guys who swear by those
If you really want the most tunable, use the newer stuff.
skeltor
Feb 2, 2016 10:37 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
toronto formula
Sep 10, 2015 07:31 AM
Ranbo108
Sep 9, 2015 12:20 PM
Jlanz55
Sep 8, 2015 11:28 PM
