have I got it
Old Mar 19, 2014 | 09:00 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
have I got it
just moved and my stuff got all mixed up.I'm putting an LG4 into my sport coupe and not sure if I have the right ecm.Service#1226455 has 5804 CJT prom in it.other numbers on the box are 845009115874144 and 16035401 CJT 865401. I think its the right one.Any one out there that knows I'd be thankfull
Old Mar 20, 2014 | 08:03 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: have I got it
CJT is for an '84 with the LG4, 700R4, and FED emissions.
RBob.
Old Mar 20, 2014 | 08:09 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: have I got it
OK,the motor and tranny came out of a 84 base modle firebird.So it should be the right one that came out of that car. I'm putting the motor and tran into a 85 camaro and from what I see in wire diagrams from austin theres almost nothing different.There are more pins on the v8 dash harness than the v6.which is what the camaro had in it before.I'm putting the tank and sending unit outa the firebird in and fuel lines.so even if some gauges dont work the motor should run,Right?
