Holley 950 Commander
Old Mar 24, 2014 | 06:47 PM
Kaytar's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: Stock Auto
Axle/Gears: No idea
I have a Holley stealth ram intake setup and the 950 commander program and hardware (ecu/pcm) It's a 350, sportsman II iron heads, 24lb injectors, a 58mm TB, SLP mid-length headers with Y and a shift kit.
I am a beginner tuner but know the basics (don't go lean, watch timing etc) I have an innovative wide band O2 so I can watch my af ratios.
How good are the base tunes for our cars?
Does anyone recommend a specific base tune to start with other than what holley recommends?
Old Mar 25, 2014 | 07:31 AM
efiguy's Avatar
Re: Holley 950 Commander
Does anyone recommend a specific base tune to start with other than what Holley recommends?
Good luck with that, the Innovates are slow and inaccurate.
Here's proof.
Otherwise most of the Holley base tunes are o.k. they'll get you headed in the right direction. Your combo is pretty straight forward.
Old Mar 25, 2014 | 10:52 AM
Kaytar's Avatar
Engine: 2.8
Axle/Gears: No idea
Where did you mount your wideband?
Driver's side bank, just below the header collector between 12:00 and 3:00?
Old Mar 25, 2014 | 04:24 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Agreed. The base tunes are pretty close. Still going to need some work to get right for your car. I have one wideband in the drivers header right after the collector controlling the computer and a separate one after the y displaying on my gauge in the dash. Also not a fan of innovate. Had issues with it grounding properly, switched to an autometer unit and no more issues.
seiplentz
Aug 19, 2019 06:02 PM
RedLeader289
May 28, 2019 01:47 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
