Air bag codes?
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Air bag codes?
Is there a way to pull codes from the air bag light? Car starts fine tests out the air bag system fine, light flashes 7 times then stays out, but after say 20 miles of driving it pops on, but as soon as the car is shut off and started the light clears out and tests fine again. Any suggestions?
Car: check
Engine: check
Transmission: check
Re: Air bag codes?
For current codes (lost at key-off), ground pin K on the ALDL connector (connect A & K together). Code 12 will flash first, followed by any current codes.
Any history codes (not lost on key-off), needs to be pulled via a Tech 1 scan tool. If code 13 is shown in the current codes, that indicates that a history code is stored.
RBob.
RBob.
Engine: 5.0 Tbi
Re: Air bag codes?
Well the light stopped pooping up, I forgot about this thread, but I thought that procedure only pulled check engine codes.
1992 Trans Am
May 10, 2023 07:19 PM
ramicio
Sep 6, 2015 11:25 AM
