Conditions for Code 44 Met, But Code Not Set. Say Whaaa?
Old Oct 26, 2014 | 04:59 PM
ĦMR.AWESOME!'s Avatar
Car: '92 RS
Engine: 305 TBI
Ahoy.
I'm trying to pass emissions. If you want, you can see my thread over in the Tech/General board here. https://www.thirdgen.org/forums/tech...emissions.html
I've got one specific question right now, however. I did a test while at 0mph and RPMs steady at about 2000. Using WinALDL, I logged the data. The 02 sensor reads 0.031-0.035V and didn't change for 61s. I'm sure the readings would stay the same if I did the test longer. The engine stayed in closed loop. No error codes were set and the SES light did not illuminate.
According to the manual, Code 44 is supposed to set when the 02 reading remains below 0.250V for 50s and the system is in closed loop.
So what gives?
02 sensor is new, btw.
Would an exhaust leak cause the reading to be so low?
Thanks.
Old Oct 26, 2014 | 07:50 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Conditions for Code 44 Met, But Code Not Set. Say Whaaa?
Originally Posted by ĦMR.AWESOME!
Ahoy.
So what gives?
Thanks.
yes ,exhaust leaks play hell with O2 sensor readings. fix that and you will be way ahead.
Old Oct 26, 2014 | 08:26 PM
Car: '92 RS
Engine: 305 TBI
Alrighty. I shall go on the hunt.
Any insight as to why Code 44 was not set?
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
GTAman
Sep 21, 2015 09:57 AM
RyanJB
Sep 2, 2015 01:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mdtoren
Aug 23, 2015 12:52 PM
