Quadrajet ECU upgrade worth it?
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
I have seen places where you can get a new chip to replace the factory one in the ecu on cars with quadrajet carbs.
Can this even be worth $165 or is it a waste of time and money? I have put in a crate motor and cam and all sort of other goodies (nothing drastic of course) but the only wired components on the engine are : Mixture control solenoid, tps, choke heater, knock sensor, oxygen sensor (not ever sure if it works, I have to check it) and the HEI distributer (stock).
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Quadrajet ECU upgrade worth it?
I have a chip. It bumps up the timing and delays the TC lockup a few mph. I would just adjust your base timing and forget the chip. WOT is adjusted by the secondary hanger and rods.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I have a 320hp 355 in my 84 T/A with the Factory 305 ECm running my Qjet. The Carb was rebuilt by cliff ruggles but otherwise is stock. the ECM runs it just fine.
MikkoV
Sep 9, 2015 04:25 PM
