Does DFI have a rev limiter?
Old Aug 20, 2001 | 08:22 PM
lexussc94's Avatar
I just installed nitrous and when I floor the car without nitrous its fine. But, when I floor it and use my nitrous it starts to go then cuts off all power to the engine. I had my DFI programmed by someone, but was wondering maybe the engine is hitting the rev limiter when it sees nitrous? Could this be? Thanks
Old Aug 20, 2001 | 10:29 PM
89ProchargedROC's Avatar
Yes there is a place in the DFI programming to program your high end rev limiter
Old Aug 21, 2001 | 05:12 AM
Alpine406's Avatar
DFI`s rev limiter is weird....if your talking ACCEL DFI.
Its not like an MSD`s, which is violent....its more like it lets the engine fire 2 times per second or something.....kinda similar to what these stock gm, ford etc...cars have for a stock rev limiter when you floor in it park.
If its not like that, its probably not your rev limiter, maybe something is wrong with your nitrous system...too much fuel or nitrous....not enough spark, too wide of a gap on your plugs and blowing out the spark....could go on
Old Aug 21, 2001 | 12:20 PM
lexussc94's Avatar
Its Accel DFI and the engine just loses all power
Old Aug 21, 2001 | 09:20 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
DFIs rev limitor was the weardes thang i ever felt
in my car.i for got to set it an it was at 5000.
whin i raced my firt race and got to 5000 there was just silence
tell i hit 2 gear and the the motor poped back on.
i would use the msd one it is not as weard.
check out my simple site at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old Aug 23, 2001 | 06:48 AM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
I assume you're talking about the Accel system...go into the Global ECU setting, pick Configure ECU and see what it is set at. The rev limiter is down at the bottom of the list.
Do you have a Hobbs(fuel pressure safety) switch on your NOS setup? You don't mention if you do or not. If you do, I'd start there.
[This message has been edited by 96BlownSSragtop (edited August 23, 2001).]
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
racereese
Oct 3, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
