Is this a good way to go to have DFI
Old Nov 25, 2001 | 09:56 AM
AustinT's Avatar
I have a zz430 and i need Dfi that will pull strong to 6000 rpm. Accel makes the computer kit to install a lt1 into any vehicle. What if I found the fuel injection off a lt1 and used the accel computer for 900 to run it?
Old Nov 26, 2001 | 07:39 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
If you run the LT1 ignition, then you will need the LT1 DFI. If you plan to do John Millican's conversion, then the factory ECM or standard DFI will work. (That's what I'm doing).
Old Nov 26, 2001 | 10:25 AM
AustinT's Avatar
Im not familiar with John Millican's conversion, where can it be found?
Old Nov 26, 2001 | 10:47 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Here is the link:
http://members.home.net/millicanga/s...into_a_1st.htm
Old Nov 26, 2001 | 05:34 PM
AustinT's Avatar
Good article!
A couple of questions,
what fires the stock Lt1 ingnition, sensor on the crank?
Where are the bolt down holes? My Fastburns have holes drilled on an angle and holes that go strait in. The Manifold I am using now, Has 2 bolts in every corner going strait down.
Old Nov 26, 2001 | 06:33 PM
RCR's Avatar
RCR
The stock LT1 uses the Opti-Spark ignition. I believe it is somehow integrated onto the timing chain cover/water pump. Not really sure. I think the extra long pin on the cam is part of it.
As for the intake, it is redrilled to match stock L-98 type heads. Check out the messages on the TPI forum for more info.
Ghettobird52
Jul 5, 2024 11:18 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
marcusaw
Aug 10, 2015 08:13 AM
