another max 232 ?
Old Dec 9, 2001 | 01:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
another max 232 ?
I went to the max sight and can not just find a max 232 they all have differant numbers after them so my question is what is the exact number I am looking for (max232????)
Old Dec 9, 2001 | 03:40 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I would use the MAX 233 for any kind of RS-232 communications. It has the chargepump caps built in, so external caps are not neccessary.
Old Dec 9, 2001 | 06:02 PM
Engine: ls1, LB9
so what are you saying? no capasitors at all? if so how should I wire it? well thanks but, I think I need to know what number max 232 I need other wise people will just give me half the story and leave me where I am now.
Old Dec 10, 2001 | 07:23 AM
RCR's Avatar
RCR
What are you doing???
My Maxim databook shows a number of different chips that do what the max232 does. There are 26 different flavors of the basic max232.
http://pdfserv.maxim-ic.com/arpdf/MAX220-MAX249.pdf
Old Dec 10, 2001 | 10:20 PM
Engine: ls1, LB9
http://members.tripod.com/moatesenhe...ecm/max232.jpg
this is what I am trying to make the problem though is if you say I can use a 233c15a or what ever the number is what do I have to change in the schematic. I almost need to see it.
Old Dec 11, 2001 | 07:50 AM
RCR's Avatar
RCR
Looking at figures 5 and 11 of the maxim pdf, you would have to make substantial changes to use the max233 to replace the max232, but you do eliminate 3 caps.
To make the swap: you would eliminate the caps between pins 1 & 3, 4 & 5, and the cap at pin 6.
Then swap the following pins: (232=>233).
16 => 7
15 => 6 & 9
14 => 5
13 => 4
12 => 3
11 => 2
On the 233, tie pins 11 & 12 together, pins 16 & 10 together, and pins 12 & 17 together.
That's it...
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Gordonr1973
Sep 29, 2015 11:59 AM
CatmanFS
Sep 19, 2015 09:00 AM
R13_Braz
Sep 18, 2015 05:00 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
