Accel DFI + CalMap 2001....... what can you tell me?
Old Dec 11, 2001 | 07:45 PM
Brett 91 RS LT1's Avatar
I'm looking into getting a dfi system when spring rolls around. Accel has released their Gen 7 version of DFI and with the many upgrades between it and CalMap 2001 it sounds like the ticket for me.
If I can scrounge the cash I hope to have the car finished off and have this installed and be ready to boost the car for the fall or the following summer.
I have a few questions though since I don't know a soul out here that is running an Accel system or anything similar.
1 - Will it allow me to totally remove the LT1 PCM or do I have to retain it? I REALLY hope to be able to can the LT1 piece because I don't have a good spot for it in my 91.
2 - Does it come as a "bolt in" kit? That is, can I order it specifically for use with the LT1 so it connects right up?
3 - Are there any modifications needed for the system to work?
4 - Having never used CalMap, how user friendly is it in comparison to LT1 Edit or Tunercat?
5 - As far as VE map, the info on the Accel sight says that CalMap comes with an Estimator. Can anyone tell me how accurate it is? I'm sure it would need tweaking, but how does it base it's projections?
I'm going to need new injectors come spring time so I figure I might as well get low impedence and hook up the DFI system in prep for the blower. That, and it will give me time to get a handle on using CalMap before I boost the car.
Thanks for any info!
1991 RS LT1 355 GTP 2 heads, GTP 6 cam....some sort of boost in the works
2000 C5 M6
Old Dec 12, 2001 | 07:17 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
Brett,
Thanks for your interest, you should be hearing from the new DFI Tech Line guy very soon to help answer your questions.
Old Dec 12, 2001 | 07:19 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I have an older DFI, so I'm no help there. As far as I've seen, your the first to post with the intention of getting the new system. Your traveling virgin territory. I'd recommend contacting Accel direct, or maybe Fuel Injection Specialties to see if they have concrete info for you. Good luck...
Old Dec 12, 2001 | 10:41 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I'm also looking for the same answers to those questions.
Old Dec 18, 2001 | 08:35 PM
89ProchargedROC's Avatar
call Turbo People in New York....They are already using it on a 2000hp+ turbo ford
they seem to like it
they can answer your questions
ask for job jr
Fanatic1074
Oct 3, 2022 05:57 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
efiguy
Sep 27, 2015 01:30 PM
e3pres
Sep 9, 2015 01:51 PM
