First time EBL. What bin to flash for my setup?
Old Dec 23, 2015 | 09:23 PM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
Hey guys. Got my EBL flash but have yet to install it. I see the bin files that come with it but curious which one should use for the initial install. Any help would be greatly appreciated.
Vortec 350 HSR
30lb accel injectors
Early fbody lt1 cam
Manual transmission
Old Dec 24, 2015 | 10:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: First time EBL. What bin to flash for my setup?
In the same folder as the BINs there is a text file that describes them. You can also open this list of BINs via the EBL Flash Program group:
Start->All Programs->EBL Flash->List of BINs
As for which one to start with, probably the 350 aluminum headed 6-speed BIN:
EBL_F_3006.BIN: 5.7l TPI, 6-spd, alum heads (Port Mod)
I would also copy the main & extended SA tables over from the EBL_F_3000 BIN
And set up the BPC vs VAC table for the 30#/hr injectors. Here is additional information on the injector compensation values:
Fuel Pressure: 43.5 psi
Flow rate: 28.8 #/hr gasoline
INJ - Single Fire Mode PW - PORT Only
Enter: 1000 usec
Exit: 1200 usec
INJ - Injector Correction Offset:
Offset Compensation versus Battery Voltage:
0.0 Volts: 870 usec
1.6 Volts: 3891 usec
3.2 Volts: 3891 usec
4.8 Volts: 3891 usec
6.4 Volts: 3891 usec
8.0 Volts: 1969 usec
9.6 Volts: 1404 usec
11.2 Volts: 1007 usec
12.8 Volts: 824 usec
14.4 Volts: 687 usec
16.0 Volts: 565 usec
17.6 Volts: 488 usec* extrapolate to 17.6 volts+
RBob.
Zylinder
Mar 23, 2016 11:00 PM
MXCamaro
Dec 5, 2015 12:01 AM
carattini
Nov 30, 2015 06:51 AM
Accerrito22
Nov 27, 2015 01:11 PM
f-bodymikey
Nov 25, 2015 01:59 AM
