305 TBI to 350 TBI swap
Old Apr 1, 2016 | 12:20 PM
HEFF16's Avatar
Car: '88 IROC-Z
Engine: 305 TBI
Wondering if anyone can help me with situation I'm going to get into. I have an 88 IROC with a 305 TBI. I'm replacing with a 350 TBI. Do I need to find an ECM for a 350 or can I modify existing ECM from the 305?
Old Apr 1, 2016 | 01:18 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Re: 305 TBI to 350 TBI swap
You just need to get a chip burned for the bigger injectors if you are using the TBI off the 350. Same ECM. You should also use the 350 knock sensor and 350 esc module they say. I have known of people just putting everything off the 305 onto 350 TBI engine and it working fine, just not getting its full potential.
Old Apr 1, 2016 | 01:20 PM
2012sergen11's Avatar
Car: 1987 Trans Am
Very straight forward as dmccain said, at least should change knock sensor, using the right chip made a huge difference in my truck. I used the 305 injectors and chip for a while but was still a dog until I swapped them for 350's
Old Apr 1, 2016 | 08:18 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Out of curiosity, have you considered different fuel injection systems?
HerpDerp1919
Jun 18, 2021 01:03 AM
Doug Phillips
Sep 23, 2016 09:25 PM
85@IRocZ
Apr 3, 2016 06:01 PM
DemonYusuke
Mar 13, 2016 02:02 PM
vash90909
Mar 9, 2016 01:57 PM
