EBL Spark tables
Old Apr 10, 2016 | 08:09 AM
slamdvw's Avatar
EBL Spark tables
Just curious if anyone has the stock SA tables for both a 5.7, and a 2.8?
If not... what would you run for timing on either motor?
I have my AFR about figured out, but still lacking power and economy ( did better with stock computer ).
Right now, I'm playing with a 5.7 in a full size truck, ran by the EBL Flash system. When I get it figured out, I'll tackle a 2.8 in a S10.
Thanks!
Old Apr 10, 2016 | 08:43 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: EBL Spark tables
There are base calibrations for 5.7l and 2.8l engine supplied with the EBL Flash. The SA tables in those are from stock GM calibrations.
If you changed the 5.7l heads to a non-swirl port need to use different SA tables. Can try the 5.7l TPI SA tables (EBL_F_3005 BIN) for non-swirl cast iron heads.
RBob.
Old Apr 10, 2016 | 04:48 PM
slamdvw's Avatar
Where are those files located? Somewhere along the line, I lost my CD - thought I made a backup of it, but can't find it.
It's got the swirl port heads ( stock motors.. )
Old Apr 10, 2016 | 05:17 PM
slamdvw's Avatar
I found 'em.. Thanks!
pfreer3
25
Aug 12, 2016 12:28 PM
IROCZ1989
17
May 11, 2016 08:22 AM
Gunsbee
Apr 9, 2016 06:50 AM
trona
Apr 7, 2016 05:35 PM
jjjosh
Apr 7, 2016 10:38 AM
