codes 41 and 42
Old Aug 24, 2016 | 01:52 PM
Dw5574's Avatar
codes 41 and 42
I have a 1989 Camaro IROC-Z with the 5.7l. The check engine light came on and I scanned the OBD1 and codes 41 and 42 came up. I took the eprom chip out and cleaned it and put back in the ECM and it ran good for about 1 day and the light came back on. Now only code 41 comes up when scanned. I checked the ground and it was fine (at least what I think is the right ground). Then I put die electric grease on the connectors for the ECM to make sure there was no corrosion and that did not help. Does anyone know what else it could be?!?!
Old Aug 25, 2016 | 08:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: codes 41 and 42
Code 41 is a cylinder select error, odds are the ECM is going south.
RBob.
Old Aug 31, 2016 | 07:32 AM
Dw5574's Avatar
Re: codes 41 and 42
Could it just be my plugs and wires going bad?
89iroc89
Feb 4, 2017 07:44 AM
Pilotrick50
Jun 14, 2016 10:08 AM
Pilotrick50
Apr 11, 2016 08:55 AM
SRKLEGIN
Mar 27, 2016 05:57 PM
Skybolt31
Aftermarket Product Review
Nov 18, 2000 11:56 AM
