Accel 7pin Large cap module
Car: check
Engine: check
Transmission: check
Re: Accel 7pin Large cap module
The only way to know is to measure it. There is a thread on the DIY_PROM board about latency and the results in testing several of the 8-pin modules:
https://www.thirdgen.org/forums/diy-...ncy-table.html
RBob.
RBob.
https://www.thirdgen.org/forums/diy-prom/465232-ebl-sa-latency-table.html Yep been there read that... was hoping someone did the math... I have a good marked damper and a advance light will check when its cooler outside...
RBob.
RBob.
Rbob whats the 3005 bins latency from? Year? Model? Large cap?
Guess I need to read more since your saying the 3005 bin is Small Cap, I'm confused why the values are larger then? Was sort of under the impression the larger the cap the larger the values should be?
Car: check
Engine: check
Transmission: check
AUJP is the 369 module.
The latency has nothing to do with cap size. It is due to the filtering done inside of the ICM. Which causes a lag in the signal to the ECM.
RBob.
RBob.
KITT1983
Apr 26, 2018 06:02 PM
WIll36
Sep 11, 2016 05:32 PM
bigarmzz
Exterior Parts Wanted
Aug 21, 2016 03:30 PM
