Bad IAC driver on ECM?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Anyone ever see an ECM/PCM where the IAC driver failed?
I've got a 16181333 PCM. I verified the wiring from the PCM connector to the IAC is fine. Using a known good iac, if I retract or extend the IAC using the laptop to command 1-160 steps sometimes it will retract, sometimes it will do nothing at all. I can't ever get it to extend.
-- Joe
-- Joe
Car: check
Engine: check
Transmission: check
Re: Bad IAC driver on ECM?
Rare, but I have had ECMs with failed IAC drivers. Usually they just don't work.
Can use LEDs to display the signal from the driver. Either one bi-color on each bridge, or two single color on each bridge. A 1K resistor works as they are usually a 12 volt signal.
RBob.
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I was going to order a IAC noid as I should have one anyway.
The car will idle at 1200rpm warm, with a target idle of 625, and iac steps of 0.
Playing with $EE_HACK, I can set the target steps from 0-160, but like I said I saw it move like once and only retract (160). It didn't even go all the way.
I did a continuity test of the wires and physically checked them from the C1 connector to the iac connector, they are fine. Tried two different off-shelf IAC's.
Do you have any experience with $EE on 16181333 ? I'd assume if the software allows you to test the valve with output steps, it actually works. So I'm guessing the problem is the PCM ?
Thanks!
-- Joe
Car: check
Engine: check
Transmission: check
I don't. I'm not sure but can the IAC be extended via the ALDL jumper and key-on, engine-off? If so just don't shoot the pintle out.
RBob.
RBob.
