305 TPI 1227165 $6E ECU idle function
Hello
It was not possible to find some detailed information how idle control works for the $6E Version.
I use Tunerpro for diagnostics and tuning and i use the file expanded.dxf
What i know.:
Idle:
Engine RPM starts with the IAC Park Position. Then the IAC moves to a second position near the desisignated idle RPM (what table is that ?)
Then the Idle function starts to control rpm (Idle RPM vs. Collant).
What Table is the input for that second position of the IAC ?
Follower:
If you hit the gas another function is adding steps to maintain driveability (steps added to Throttle follower in drive)
The following tables and scalars are of interest:
-Warm IAC Park Steps vs. Coolant(0x588)
-Idle Speed Time Out IAC Steps vs. Coolant or MAT(0x59F)
-IAC default keep alive motor Steps(0x597)
Which table is the baseline and how are the steps calculated when the car is moving ?
Are there other parameters to look at ?
Thanks a lot (please forgive me my bad english).
What i know.:
Idle:
Follower:
