Aldl pinout
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Aldl pinout
I'm having trouble finding a pinout for the obd com port that makes sense.
92 5.0 TPI
F E D C B A
G H I J K L
A is ground.
B is diagnostic 5v
C is unknown
J is 5v <----------- WHAT is this for?
K is unknown
L is 8192 serial data
Others have no pins.
Can anybody fill in the blanks especially J. I want to know if I can power anything with J or why not.
92 5.0 TPI
F E D C B A
G H I J K L
A is ground.
B is diagnostic 5v
C is unknown
K is unknown
Re: Aldl pinout
All I know is that if you have the wiring diagrams for the car, you can flip thru the pages relating to the EFI and transmission and look for the wires that terminate at the ALDL. I'd trust that further than any diagram found online, it'd just take a bit of studying to research.
Car: check
Engine: check
Transmission: check
Re: Aldl pinout
Lower terminal letters didn't use I, looks too much like a 1.
A is ground.
B is diagnostic 5v.
C is unknown. Not sure what would be there.
F should have the TCC on it, pin F6 on the ECM, it also goes to the TCC solenoid.
K is 5v. Diagnostic request to DERM
L is unknown.
M is 8192 serial data. ALDL and DERM
RBob.
Code:
F E D C B A G H J K L M
B is diagnostic 5v.
L is unknown.
RBob.
Engine: LB9
Axle/Gears: 3.08
Re: Aldl pinout
A is ground.
B is diagnostic 5v.
L is unknown.
RBob.
Code:
B is diagnostic 5v.
L is unknown.
RBob.
Interesting that there's still unknowns after 30 years!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Aldl pinout
L is a serial data if used.h abs diagnostic . C air divert ground.
