Reading Datalogs on my 89' GTA
Old Oct 3, 2018 | 08:07 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
So I've had a ongoing issue with a misfire most noticeable at idle and a vibration after around 4500 rpms (I assume is a misfire also). The car is an 89' Trans Am GTA, the engine is a stock replacement 350 TPI, supposedly its .040 over, has a comp xr269hr cam, 21lb accel injectors, aftermarket fuel pressure regulator, accel runners, edelbrock high flo base, underdrive pulleys, and it was supposedly had a chip burnt by TPI chips. I'm new to Winaldl but from what I can tell is the car is way lean, especially below 2000 rpm and leans out again at around 4800. If someone could read these and give their opinions, etc I'd appreciate it! Thanks
File Type: txt
File Type: txt
Old Oct 3, 2018 | 08:31 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Reading Datalogs on my 89' GTA
You should try using tuner pro rt. Much easier to see the data.
Old Oct 3, 2018 | 08:43 PM
I'll check it out. Thanks!
Old Oct 3, 2018 | 08:46 PM
Engine: Lb9
Transmission: M20
Thirdgen89GTA
Dec 14, 2004 12:56 AM
ben73
Aug 25, 2004 09:26 AM
dimented24x7
Jan 26, 2004 05:03 PM
