1227730 Converted to MAF
Looking to run a MAF on a 1227730 ECM, I know it can be done as they offer it here: Mass Air Flow harness for modified GM Tuned Port Camaro/Firebird/Corvette 5.0, 5.7 Engines (1985-1992) https://www.ronfrancis.com/prodinfo.asp?number=TP%2D30, So I figure some one knows how to DIY it.
Also perhaps for this ECM as well?? 1993 16168695 it is also a MAP system I might need to convert to a MAF...
And on GM MAFs I thing I saw a tread on converting our 86 to 89 GM MAFs to use Ford MAFs??
Rich
Rich
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1227730 Converted to MAF
Never heard of the 730 running a maf.
the 808/165 can do maf or map
Engine: Lb9
Transmission: M20
The Ron Francis looks like a big junction box. A waste of money
larry’s electric has a good price on the 730 Harness.
OK I found larry’s electric at http://www.larryselectricsite.com/, BUT I could not find a MAP to MAF convertor hardness.
Still looking for how to do this myself.
Rich
Rich
Engine: Lb9
Transmission: M20
Don’t believe there is such a harness, what mask are your referring to ?
Engine: Lb9
Transmission: M20
Yeh, looks like a mistake in listing and it’s for the 1227165 and maybe the 870 ecm.
call them and inquire. @RBob would know if the 730 can support maf but I doubt it.
I was miss lead, it is a wring hardness TO Swap a 6365722 system INTO a car...
Rich
Rich
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Best of luck,
- Rob
There is no reason to go to a MAF sensor on a 7730. That's really stupid.
GD
GD
