craig moates software
Old May 17, 2002 | 01:19 AM
91L98Z28's Avatar
Car: Z28
I've build a 2-transistor cable and am using the 8.45 version of the scanner...links up ok and everything seems to work fine, however i don't seem to be able to dump memory? I always get a timeout error instantly. I get perfect data otherwise (no errors, ~10hz data speed, etc.)
'730 ECM, stock memcal.
what address range should I be dumping?
Is there any way to get the NVRAM dumped, so you can see the BLM cells etc?
thanks....
Old May 17, 2002 | 02:41 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
The memory location ranges should be listed somewhere, you can do a search... The defaults I think are wrong for the 730, but correct for th e 165.
Why is it timing out during that task and not others? That's odd. You're sure you're connecting OK & all, so I guess that's not it. Hmmm... Still haven't got it to go I assume? Maybe someone else can chime in with their difficulties turned success.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Deemax
Sep 12, 2015 06:53 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86camaroman201
Aug 19, 2015 04:52 PM
