BPW constant...here's what I'm thinking...
Old May 22, 2002 | 05:59 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I've searched thru the archives a couple times trying to figure out if raising the BPW makes the AFR richer or leaner.
Maybe I'm looking at this wrong but consider this...
Using the BPW constant formula I find the BPW for a 350 with 61.2 lb/hr injectors...and then the same 350 with 90 lb/hr injectors.
Val = 1461.5 * (VOL/RATE)
61.2 lb/hr = BPW 135
90 lb/hr = BPW 91
Since a bigger injector will flow more lb/hr...then wouldn't a lower number correspond to a leaner AFR? If the 90 lb/hr injector can flow more fuel in a given amount of time then wouldn't you need to lean it out. So by that reasoning wouldn't a lower number = a "leaner" BPW?
Old May 22, 2002 | 10:13 PM
Brent's Avatar
Raising the BPW constant richens the fueling globally. The opposite leans fueling globally.
Old May 22, 2002 | 10:31 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
That's what I thought. If you search the archives you'll find that every post says the opposite of the one right before it.
87hellbird
Sep 14, 2015 05:08 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
funstick
24
May 15, 2003 09:03 PM
JPrevost
Jan 12, 2002 06:25 PM
Dan W
Jun 10, 2001 12:33 PM
