Tuning For Track-help
Old May 24, 2002 | 07:15 PM
CHOANER's Avatar
I've been tuning for just a few weeks now and have gained much drivability.
I do not have a wb O2 yet nor have i even done any wot tuning
other than bringing total timning in sooner,my question is there
anything somebody would recomend to help ET ? like should I
bring in PE at a lower % or anything similar?
going to track on sun. Thanks for any help.
87 T/A DEF. 6E
Old May 24, 2002 | 07:26 PM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
https://www.thirdgen.org/techbb2/sho...hreadid=107391
In that thread you might find out how rich WOT AFR's are. Make small changes and measure the performance. If it gets better, do it again. Always track performance and knock.
Old May 24, 2002 | 09:19 PM
CHOANER's Avatar
thanks for reply,
I understand what i need to do but dont have a lap top to do field
changes.
I just was unsure if there were any small proven changes that help ET - like i said would lowering % to enable PE help anything?
Thanks again.
Old May 24, 2002 | 10:48 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
Well, that's a tough one to answer. I guess it depends on how you launch. If you ease into the gas because of traction problems or sometihng like that maybe it would be better to raise it instead of lowering it. That way you can launch harder, maybe. If you just gun it out the gate then it won't make a difference. As far as not being able to make changes on site, just burn a bunch of chips with minor changes to each.
Old May 24, 2002 | 11:06 PM
CHOANER's Avatar
Thanks Hect,
Thats pretty much what i did,but only have 3 extras.
I leaned inj const a little on 1, and the other 2 i brought adv in
earlier that the previous.
Thanks again.
Zell1luk
Sep 29, 2015 10:36 AM
