Hey guys,
Just completed the swap to 730 from 165 and got rid of
esc failure code - was due to knock sensor.
Well i plugged in my scan tool to get some data and to my surprise i have no load value showing on my scan tool...
When configured for 165 i had a kpa value.
Now i dont and the only thing i can think of is i config. the tool
with vin # 8 (for 8th digit) and F (for fourth dig) Is that right for a
90-92 f body 5.7?
I think there is a way to calculate KPA is'nt there?
W/out that i cant start on the VE tables.
Thanks for any help.
90-92 f body 5.7?
Im sorry for previous message i meant Map KPA,
I do display a Map voltage but what does that convert to?
tunercat shows 20 to 100 my volts are 2.-- on scan tool.
Thanks HH but my scan tool only ask for 4th and 8th
and those are the same as yours.
I called auto x and they said the scan tool only reads a signal that the ecm gives.
How is your map voltage displayed?
is there a seperate for kpa?
